98 Disco 1 no start when below freezing.
Old Mar 13, 2022 | 11:37 AM
ProfGriff's Avatar
Default 98 Disco 1 no start when below freezing.
My Disco has started an annoying new trend. It refuses to start when it's below freezing outside.It will crank and crank but not fire at all. As soon as it's above freezing it starts on the first crank every time. This is rather frustrating since I live in Canada and it's almost always below freezing this time of year. The truck has no DTC's and has new plugs and plug wires.
Any suggestion?
Thanks all!
Phil
Old Mar 13, 2022 | 12:42 PM
stillruns's Avatar
Do you keep it on a trickle charger? What is a DTC?
Old Mar 13, 2022 | 02:12 PM
JohnZo's Avatar
Default Throttle plate clean?
Maybe try an additive to the gas tank to remove water. Make sure the muffler drain holes are open too. Have you cleaned the throttle plate and IACV passages lately?
Old Mar 13, 2022 | 03:38 PM
ProfGriff's Avatar
DTC= diagnostic trouble codes, of which it has none. I don't have it on a trickle charger, but it won't start with a booster pack either. There is injector cleaner in the gas that should look after water too. I have not cleaned the throttle plate or the IACV. My Disco was sitting for almost a decade and I've only had it on the road a couple of months. It's just weird that it starts instantly when it's above freezing. I'll clean the TB and IACV anyway, because that's basically free.
Thanks guys!
Phil
Old Mar 14, 2022 | 07:02 PM
Machinistbutler's Avatar
On diesels sometimes fuel filter or water separator can freeze up not letting any fuel through. I am not sure if somehow the filter could have water in it and not let the gas through ?
Old Mar 14, 2022 | 07:04 PM
Maybe try a whiff of starting fluid, if it fires then it must be a fuel problem.
Old Mar 14, 2022 | 11:43 PM
jvarnadoe's Avatar
Dude! My first car was a '72 MGB GT with crazy loose wire wheels. Man, I wish I had kept that car.......
I pushed it almost as much as I drove it, but I loved that car. :-)
Old Mar 23, 2022 | 06:10 PM
jimvw57's Avatar
Check the connectors on the computer under the hood. they may be corroded and not make contact in the cold weather.
Blamo35
Jan 18, 2022 08:21 PM
Woody Reems
Jul 14, 2009 08:30 AM
discohio
May 14, 2009 12:58 AM
cellman01
May 4, 2009 11:57 AM
Spots and Dots
Dec 12, 2007 09:19 AM
