98' disco does not want to drive straight.
It could be; bad pan hard bushings, bad tie rod ends, bad steering box,bad control arm bushings/loose bolts, bad pit man arm, loose steering box bolts, bad intermediate steering shaft, swivel pins need adjustment, bad tire or you just have the toe out of whack
Sway bar will not make you wander all over the road, guys with lifts remove them no Ill effects
Don't forget bad shocks and worn out springs
My 98 handles no different with the bars off the when they were on, vehicle is a top heavy brick and sways some either way, unless he has an end link broke off doubt they are causing his issue, probly like the rest of us he bought a rig that was poorly maintained with a crap load of worn out parts
