'98 Disco I - Good but economic fuel pump
  #21
Old 09-27-2011, 01:39 PM
Jaace's Avatar
Wow...that actually looks really straight-forward. Thanks for the info!
  #22
Old 09-27-2011, 01:50 PM
Chris-bob's Avatar
I think I did the entire job with a phillips screwdriver and 2 line wrenches. Can't remember the size of wrench off the top of my head, but someone here might chime in.
  #23
Old 09-27-2011, 03:16 PM
Paul Grant's Avatar
Chris-Bob the lines connect a little differently on the AES versions. No need for the 14mm wrenches. It's a push pull configuration similar to what you'll find on DII's.
  #24
Old 09-27-2011, 04:38 PM
Chris-bob's Avatar
Even easier then!
  #25
Old 09-27-2011, 06:43 PM
The hardest part about changing my fuel pump was getting the retaining ring off.
  #26
Old 09-27-2011, 06:46 PM
Originally Posted by Jaace
The other issue is that I was concerned about compatibility: I did hours of research on what to get last night and had certain people tell me fuel pumps would work, while others said those same pumps were no good. I am not sure who to believe anymore...but the fuel pump I did purchase came out of a truck the exact model and year as my own.
You think it is confusing now, just be glad you dont own a '99, there were 2 different model Discovery's sold in that year with almost zero interchangeability between the 2.
  #27
Old 02-09-2015, 10:53 AM
johnrocksteady's Avatar
Originally Posted by Disco Mike
Don't buy a used pump, cause that is just what you are getting a used, partially warn out low pressure pump. Buy the AirTex, it is a great pump with slight higher fuel pressure then the original which is great when dealing with warn out injectors.
I am looking for a replacement fuel pump for my 98 disco.
This thread recommended the Airtex E3270.
Ebay does not have my disco under "compatible" vehicles
Airtex website gave me the E8388M model, is this the one you were mentioning?
  #28
Old 02-09-2015, 04:38 PM
MM3846's Avatar
the E3270 is not the "correct" pump for this truck. If you want to do it this way, use that pump. If you want a bolt in solution, you'll have to pay more.
  #29
Old 02-10-2015, 11:38 AM
fishEH's Avatar
Sort of........
Land Rover wants you to buy the entire pump assembly. On an EVAP vehicle its pretty darn expensive.
The entire assembly (usually) isn't the part that goes bad. Usually its just the pump itself, which is what the Airtex is. The actual pumps look IDENTICAL. The plug on the pumps is IDENTICAL. The only part that has to be changed is the fuel lines. You have to replace the flexible "straw" with fuel injection line and a couple clamps. It really is just that easy and as "bolt in" and is "correct".
Its like if the muffler on your truck goes bad. Is it "correct" to have a new one welded in? I would say so, but Land Rover would say the "correct" way to do it is to buy this.
http://www.roverparts.com/Parts/NTC7426K
Both are "correct", but why spend more money on parts that aren't actually broken and don't need to be replaced?
  #30
Old 02-10-2015, 02:07 PM
pinkytoe69's Avatar
Originally Posted by fishEH
Sort of........
Usually, but not always.
When I went in to replace the pump on my AEL D1, I found the plastic around both the input-output nozzles was cracked pretty bad.
Because of that, I opted to replace the whole assembly.
Quick Reply: '98 Disco I - Good but economic fuel pump
