99 dico sd steering
Old Jun 14, 2011 | 04:07 PM
LRD2&ME's Avatar
From: Oklahoma; where the winds come rolling down the plains.
If all the joints are good. The steering gear box backlash ALLEN bolt is used to correct the excessive play. You will need to jack up the front end with the tires off the ground. Disconnect the steering gear box arm from the tie rod. Now check for backlash in the gear box. Move the arm side to side. You should feel movement if it is not backlashed properly. Use the steering backlash bolt and adjust it until the play is just close enough to not wiggle. This is the best way to test and correct steering gear box backlash play.
Old Jun 14, 2011 | 04:42 PM
Chris-bob's Avatar
Originally Posted by Spike555
Take it to the closest suspension shop for a free inspection.
Then let us know what they tell you and the price quoted.
I keep forgetting that in the real world many shops will still inspect for free.
Old Jun 14, 2011 | 05:28 PM
LRadventure's Avatar
Do these have rag joints in the steering column ?
Old Jun 15, 2011 | 09:01 AM
kingnebby's Avatar
Originally Posted by turf63
Death wobbles?
yes i do get the death wobble when slowing down from high acceleration
Old Jun 15, 2011 | 09:05 AM
kingnebby's Avatar
will give it a go this weekend and give update, thanks for the info
Old Jun 15, 2011 | 09:07 AM
kingnebby's Avatar
everything is stock
kfx4001442
Apr 7, 2008 05:52 PM
NWDiscoRover2004
Nov 6, 2007 11:05 AM
billinohio
Feb 28, 2007 12:03 AM
cowgirl1989
Dec 18, 2005 07:15 AM
958mtm
Dec 13, 2004 05:41 PM
