ABS Code 2-8 Faulty Valve Relay
Old Jul 4, 2016 | 01:56 PM
dsmeddy's Avatar
Default ABS Code 2-8 Faulty Valve Relay
Happy Independence Day to all.... I just read a 2-8 code on my ABS light ..... Where do I find the ABS Valve Relay ? Part #? and/or where to purchase???
Many Thanks
Old Jul 5, 2016 | 11:00 AM
WaltNYC's Avatar
Not sure exactly which relay is the issue...
Old Jul 5, 2016 | 03:32 PM
dsmeddy's Avatar
Oh geez, there are many... Thank you for the diagrams
Old Jul 9, 2016 | 09:48 AM
dsmeddy's Avatar
I replaced the black 12v relay (K102). The ABS light went off for a moment but came back on. Would you suggest me to change the other 2 (K101 & K103)as well???
Under Passenger Dash Board
Old Jul 9, 2016 | 11:43 AM
Paul Grant's Avatar
I could be wrong but I don't think this is an electrical relay issue. More likely a valve in the ABS modulator. Kind of like the shuttle valve failure in the DII modulator.
Old Jul 11, 2016 | 09:49 AM
WaltNYC's Avatar
two questions...
1. yeah, the light came back on but is it the same blink code?
2. What year is the truck (you should always put this info in your signature line so it is easier to help)
bonus 3. Paul knows these trucks as well as anyone (and definitely me), but I've not heard of a valve failure on a D1. Relays are relative inexpensive so it can't really hurt to remove them from the puzzle.
Old Jul 11, 2016 | 06:19 PM
dsmeddy's Avatar
My bad... 1997. I've ordered some relays and already replaced 1. Seems like Paul seems to think it may be a valve rather than a relay. I have'nt checked the code since the 1st initial check. I just pulled the 30Amp fuse until I get the other 2 relays and replace.
bleizit
Jun 24, 2020 04:03 AM
RicketyTick
Jun 24, 2014 06:58 PM
archaeology_student
Apr 7, 2013 09:26 PM
mzcharlene
Jan 17, 2013 03:07 PM
s10lowrider1994
Oct 6, 2011 01:22 AM
