ABS pump relay
So, I went muddin last night, and i went through a mudhole and it killed the rover, I tried starting it and as soon as i got the ignition ON but not cranking this ticking starts under the glovebox, So i spend a couple hours today and i figured out what was ticking, http://www.roverparts.com/Parts/AMR3773.cfm That thing. So i yanked it out and it starts just fine, ANTI lock stays on and im sure i dont have ABS but common sense says if i replace the relay i should be good right?
Im 100% sure. Looked the part up online. It made a horrible ticking noise just like the sound when ABS is working when i tried to start it, It would crank over but not start. I took the relay off and it started right up. I put it back on and no problems... WEIRD!
Travelor
Sep 24, 2015 06:11 PM
tre976
Apr 16, 2008 08:33 PM
