adding more 12v sockets
Old Jun 29, 2014 | 08:29 AM
bearskinrug's Avatar
Default adding more 12v sockets
Couldn't find a good post for this, so I thought Id ask for help adding 12v plugs to the interior of my 98 dI. I was thinking about replacing the cigar lighter with a blue sea usb port, and adding an american sized 12v cigaret lighter plug for other stuff. Anyone have advice or walkthrough on this? I'm electrically retarded.
Old Jun 29, 2014 | 08:51 AM
fishEH's Avatar
I did this in my D1. I left the cigar lighter though because I have some stuff that fits it and changing it looked like a PITA.
I bought some Marinco 12v outlets off eBay. Just like these.
Robot Check Robot Check
I made a template and drilled the trans tunnel trim. There wasn't a lot of room behind the receptacles so I used Flag Terminals. I crimped them with a pair of channel locks.
The hardest part was running the wires discreetly. The two additional receptacles are always hot which is nice.
Finished product.
Old Jun 29, 2014 | 09:22 AM
That looks awesome! Exactly the sort of setup I was thinking of. It looks like you accessed the wiring harness through the glove box? Where I really get stumped is how to wire the new port into the harness. Do you have to cut and splice? And what about fusing the things? Before I tear into the dash do y'all have any tips? Thanks again for your help.
Finished product.
Old Jun 29, 2014 | 09:39 AM
fishEH's Avatar
I'm actually taking power straight from the battery via an auxiliary fuse box I installed in the engine bay. Thw wire comes in through the firewall on the drivers side and then sneaks behind the dash over to the passenger side. Without doing all that you could.....run a wire straight from the battery, punch it through the firewall wherever you could, add an inline fuse, and run to the sockets.
Having the receptacles be always hot is really helpful.
Old Jun 30, 2014 | 08:28 AM
TOM R's Avatar
On my list of things to do is I got a d2 rear aux to add, need power jack at rear of console for the monster and was thinking bout adding this on dash in that slot above coin tray Dual Ports USB Motorcycle 12V Cigarette Lighter Power Integration Outlet Socket | eBay
Old Jun 30, 2014 | 09:10 AM
fishEH's Avatar
That thing is pretty slick and a good deal for the parts you get. I may pick up one and swap out one of my standard receptacles for the USB one.
The double unit may be a tight squeeze above the ashtray though.
Old Jun 30, 2014 | 09:22 AM
TOM R's Avatar
That is the problem I have buying online, no demensions so can only guess the size
Old Jun 30, 2014 | 10:01 AM
fishEH's Avatar
Well, the socket part alone takes a 1-1/8" hole to mount. The front lip is a slightly larger diameter than that, I'd guess 1.25" OD. So two sockets side by side would need 2.5" bare minimum to mount, probably figure 2.75" to be safe and leave enough room to turn the securing nuts on the back of each one. I have no idea what the spacing is on the plate provided in the link but I'd guess at least 3" overall width.
Old Jun 30, 2014 | 09:43 PM
TOM R's Avatar
Well the overall on the pocket is about the size of a credit card
Perfectphoto
May 31, 2015 04:39 PM
fishEH
Jul 24, 2013 09:09 PM
kevin cassidy
Mar 30, 2012 04:53 PM
bcolins
May 13, 2011 01:31 AM
bantham1
Jun 10, 2010 05:15 PM
