Aftermarket Stereo Install Issues, No Ignition Power
Old Jul 23, 2019 | 09:00 PM
WeekendWarriors87's Avatar
Default Aftermarket Stereo Install Issues, No Ignition Power
Hey everyone, so I have read every single thread about installing an aftermarket stereo and was ready for amp problems etc etc, but my first issue is that I have no power! So when I test the 12V memory wire, i get 12V read on the voltmeter so that one is good, I also tested ground so I know that works. However, the orange/green ignition 12V does not have any power. I traced it down into the passenger glovebox area and can see that it disappears into a massive bundle of wires and cant follow it from there. It does not seem to actually run to the amp, so I am guessing it runs right to the fuse box. Is this a known problem? Is there anything I can do short of running a new wire? And if I have to run a new wire, is there an easier way to do it? (say by tapping another wire in the passenger glove box that also runs off 12V accessory?)
Thanks in advance everyone, this forum has been extremely helpful on my restoration so far. Pics of the mess of wires wouldnt help much, but heres a pic of the truck just for fun.
Old Jul 24, 2019 | 12:30 AM
Icannap1's Avatar
you can tie into the cigarette lighter as that circuit is switched.
Old Jul 24, 2019 | 06:48 AM
Thanks! I will keep that one in mind if I cant find the real problem
DakotaTravler
Mar 31, 2019 12:10 PM
micahb
Mar 5, 2018 02:48 PM
LR03NJ
Jan 14, 2017 12:41 PM
batard
Dec 19, 2015 11:05 AM
tlbslc
Nov 24, 2009 12:08 PM
