Almost there.......
Old Apr 29, 2012 | 05:06 PM
Boxkid1's Avatar
Default Almost there.......
Gents,
Refurbing the 94 Disco and am making good progress. PS pump, soldered ECU, new window motors , O2 , F/R diff oil , T box oil, brakes all around , POR 15 all over the sketchy rust spots, assorted plastics and such, new rubber manyana. I need an idea of cost on what seems to be my biggest remaining issue. Had the swivel pin service done and the drivers side leaks like a bitch. Evidently a seal or gasket ( havent looked into the details , as ive been under the hood all weekend !) . Any idea of complexity of the job and cost. Can a backyard mechanic execute ?
Thanks in advance for the replys.
Old Apr 29, 2012 | 05:55 PM
In addition to diy repair, consider change from oil to "00" grease (see local lawn mower shop). If you don't wade a lot, drain and refill of swivels is not common, many have switched to grease.
Old Apr 29, 2012 | 06:02 PM
Here is what I did to "fix" my leak.
Gaiter Kit For Swivel Housings (Part # DA3057) - Land Rover kits from Atlantic British
Works great.
Takes about a hour to install both sides.
Old Apr 30, 2012 | 07:41 PM
Boxkid1's Avatar
Drained the trouble swivel today and tossed in the LR grease packet , as recommended. Looks good and is spot free so far. Only issue was I could only fill 1/3 of the bag . I thought it was a one shot . Thought i'd be able to fill it with more . Ideas ??
Old Apr 30, 2012 | 07:51 PM
Turn the wheel as far as it can go towards the outside and spin the wheel, spinning the wheel with bring the lube down into the swivel.
Old Apr 30, 2012 | 08:26 PM
oilspotLR's Avatar
You should be able to get 1 full bag in each... At least I was able too...
Old Apr 30, 2012 | 08:50 PM
black sheep's Avatar
Maybe half in the fill plug and half in the drain plug? Just my.02....
Good luck
Old Apr 30, 2012 | 09:24 PM
oilspotLR's Avatar
Drain plug is on the side so Putting it in through that may not be a good idea.
Old Apr 30, 2012 | 09:29 PM
The drain plug was done away with in late '96.
Thats when they switched over to the "00" grease.
Old Apr 30, 2012 | 09:38 PM
Got it. I have both the top and bottom plugs on my '96, iirc the top is a smaller diameter.
