Almost there.......
Gents,
Refurbing the 94 Disco and am making good progress. PS pump, soldered ECU, new window motors , O2 , F/R diff oil , T box oil, brakes all around , POR 15 all over the sketchy rust spots, assorted plastics and such, new rubber manyana. I need an idea of cost on what seems to be my biggest remaining issue. Had the swivel pin service done and the drivers side leaks like a bitch. Evidently a seal or gasket ( havent looked into the details , as ive been under the hood all weekend !) . Any idea of complexity of the job and cost. Can a backyard mechanic execute ?
Thanks in advance for the replys.
In addition to diy repair, consider change from oil to "00" grease (see local lawn mower shop). If you don't wade a lot, drain and refill of swivels is not common, many have switched to grease.
Here is what I did to "fix" my leak.
Gaiter Kit For Swivel Housings (Part # DA3057) - Land Rover kits from Atlantic British
Works great.
Takes about a hour to install both sides.
Works great.
Drained the trouble swivel today and tossed in the LR grease packet , as recommended. Looks good and is spot free so far. Only issue was I could only fill 1/3 of the bag . I thought it was a one shot . Thought i'd be able to fill it with more . Ideas ??
You should be able to get 1 full bag in each... At least I was able too...
Got it. I have both the top and bottom plugs on my '96, iirc the top is a smaller diameter.
