Alternator Alternatives
Old Jan 10, 2012 | 03:59 PM
EricTyrrell's Avatar
Default Alternator Alternatives
Is anyone aware of any alternators that are worth purchasing over the Magneti Marelli? Not talking about rebuilds, just new or remanufactured.
Here are the alternative brands I'm aware of:
Allmakes
Allmakes Prestolite
Denso
Davis Unified Ignition
Pure Energy
Beck/Arnley
Remy
Bosch
ACDelco
Some of those brands seem reputable for quality parts, but I still don't know.
I'm particularly interested in Davis Unified Ignition's Mr. Amp 130W alternator.
http://www.summitracing.com/parts/DUI-MR-130-LR/
http://www.performancedistributors.c...tors-mramp.htm
Old Jan 10, 2012 | 04:26 PM
jafir's Avatar
I believe I've seen posts that Will Tillery sells high amp alternators. You might give him a call.
Old Jan 10, 2012 | 05:11 PM
And don't forget to check with your local indy starter/alternator shop
Old Jan 10, 2012 | 06:42 PM
Danny Lee 97 Disco's Avatar
What is wrong with yours? Have you priced getting it rebuilt or was the case damaged?
I would check with Will Tillery and /or Paul Grant for a good used one. The local recycler here sells the ones they remove at a good price.
Even the remanufactured ones often do not hold up if they use the cheapest parts available. Hard to beat the MM.
The first one you linked to has a v belt pulley, you need a serp belt pulley, right?
Old Jan 10, 2012 | 09:23 PM
You can swap the pulley's.
You cant ever go wrong with anything Denso.
Old Jan 10, 2012 | 10:00 PM
Yeah it's serpentine. My alt's case is cracked and who knows how old it is, so I'm not going to wait around for it to fail on me in the woods. The sooner I replace it, the sooner you get to disassemble it too Danny.
Old Jan 10, 2012 | 11:50 PM
psykokid's Avatar
Some Bosch VW alternators are known to fit with a little modificaiton.. I know that the VR6 alternators are 120A and have read that they fit with the above caveat..
Old Jan 11, 2012 | 12:57 AM
s10lowrider1994's Avatar
I like the Denso alternators. Not sure if you have a salvage yard nearby but I grabbed a spare one a while back out of boredom for $15 from the pick a part.
Old Mar 6, 2012 | 06:44 PM
As a follow up I ended up purchasing the Denso for $200 from BritishPacific. It seems to be the best balance between price and quality. The new Denso is practically identical to the Magneti Marelli in appearance and design. The old MM produced 13.91V at idle, and the new Denso 14.07, hardly a difference.
Old Mar 6, 2012 | 07:24 PM
Where did you buy your Denso alt Eric?
