Am I missing something
Old Jul 9, 2016 | 09:51 AM
dsmeddy's Avatar
Default Am I missing something
I have 2 empty relay spots under my drivers seat. I haven't a clue what they are for. I do know my drivers seat wont adjust the front of my seat up nor down. Could this be why???
Missing relays for....?
Old Jul 9, 2016 | 10:59 AM
ihscouts's Avatar
Seat heat I believe for both front seats. If tilt isn't working it's usually the switch, hit that with WD40.
Old Jul 10, 2016 | 09:31 AM
fishEH's Avatar
The seat switches can be taken out and cleaned relatively easily if you're careful keeping the parts contained.
Old Jul 11, 2016 | 09:34 AM
WaltNYC's Avatar
Very carefully indeed. There are a bunch of tiny springs and ball bearings in there.
Use a thin smear of dielectric grease on contacts when re-building.
Old Jul 11, 2016 | 06:20 PM
dsmeddy's Avatar
Oh goodness... Thanks for the heads up. Will proceed with caution.
Old Jul 11, 2016 | 09:02 PM
number9's Avatar
Disassembling in clear plastic bag helps retain the small parts.
Old Jul 12, 2016 | 05:01 AM
ihscouts's Avatar
It's not the quantity of parts, it's the size with large fingers.
Old Jul 12, 2016 | 09:08 AM
fishEH's Avatar
There's a write up on here somewhere on rebuilding these. I used a little 2000 grit sandpaper to polish up the contacts and then just a tiny bit of dielectric grease.
Old Jul 12, 2016 | 10:09 AM
ihscouts's Avatar
Wasn't it you fish that did it last year?
Old Jul 12, 2016 | 10:12 AM
fishEH's Avatar
I did the repair a few months ago but didn't do a write up on it.
My buddy Eric did the write up on it. https://landroverforums.com/forum/di...witches-62504/
I know, us IL guys all look the same.
