Another High Idle Diagnostic
Old May 25, 2021 | 12:30 PM
lacucaracha's Avatar
6th Gear
Default Another High Idle Diagnostic
So my wife's 1998 discovery 1 v8 has a high idle, somewhere around 1200 RPM.
I tried diagnosing and come to the following conclusions. With the A/C on or off there is only a temporary change in the idle speed, so I ruled out the IACV.
When I remove the TPS from the throttle body, but keep it plugged in, the idle speed drops to 700RPM- which is correct.
So- I either have a bad TPS, or the computer needs to relearn what zero is when the TPS is actually installed and has some pressure against it.
My Question is should I:
A. Get a new TPS and take it to a Land Rover specialist to have the ECU reset to accept the new one
B. Simply have the ECU reset to accept the TPS as at "zero"
C. Look into a new ECU/TPS
The high idle was a bit of a sudden issue, and I am confused why this would be. I am not able to locate any vacuum leaks but could keep trying.
THANKS!
Old May 25, 2021 | 01:48 PM
WaltNYC's Avatar
The best idea I have is to get a obd dongle and an app for you phone so that you can actually see what the sensors are sending to the ECU. You may need a new tps and you may need to re-flash your ECU. You can re-flash it yourself using robertf's application.
https://landroverforums.com/forum/di...33/#post598538
Old May 25, 2021 | 03:17 PM
6th Gear
I have an ODB reader that is showing 11% on the TPS.
I have an IPhone but I will do some research on what you posted.
Edit, I see that it's mac compatible so maybe I should pick one up! If resetting is the best idea
Old May 25, 2021 | 03:46 PM
WaltNYC's Avatar
11% TPS at idle sounds about right.
IIRC robertf's application only runs on Android devices.
https://play.google.com/store/apps/d...ms.gemsutility
Old May 25, 2021 | 03:52 PM
6th Gear
So if unscrewing the TPS, but leaving it plugged in yields an idle at 700, what would you all do?
Old May 27, 2021 | 06:38 PM
leecatd8209's Avatar
There's a free app that will allow you to reset the adaptive values in the ECU with a bluetooth dongle. It doesn't hurt anything to do it.
When I was chasing an intermittent high idle resetting the adaptives on first start would make it go away for awhile. Then it stopped working altogether. Then a few weeks down the line I'd be cruising along and hit random choppy fuel cut. Then when I ordered a $60 Jeep TPS it finally started spitting out TPS codes. Replacing the TPS fixed everything.
Old May 27, 2021 | 06:49 PM
6th Gear
What year make and model jeep has the same TPS?
Old May 27, 2021 | 07:07 PM
what year make and model jeep has the same tps?
napa p/n: crb 21856
Old May 27, 2021 | 08:28 PM
JohnZo's Avatar
Default Idle air valve vs TPS
If you are strapped for cash, and don't have time to do the Adaptive Reset gambit, it is easy to file out the holes on the TPS a little bit and rotate it slightly CW, so the resting value is less than the base value memorized by the ECU. I did that to solve the high idle on my 96 D1 a few years ago. Whenever the TPS resting value is more than the memorized base value, the engine revs high at start. That is why taking it off works, since the value goes to zero. So that can happen with a new TPS as well, it just depends on your luck. That's why it is good to have a scanner that can show your throttle position, then write it down in your shop manual, just like me. Now if I could remember where that manual is.... PS That NAPA part (CRB 21856) is the IACV (also shown in the photo), not the TPS.
TPS rotated a bit CW
Last edited by JohnZo; May 27, 2021 at 08:48 PM. Reason: Info about CRB 21856 part
ajnolin
Feb 3, 2020 10:21 AM
PNW Disco
Aug 29, 2017 12:11 PM
rubbamade
Jan 29, 2014 04:23 PM
bushpilot
May 12, 2013 10:21 PM
Sarge103
Jan 31, 2013 05:26 PM
