Another VSS question....and a random
Old 01-29-2013, 04:03 PM
Discolife's Avatar
Hey guys, does the VSS effect the cruise control in any way?
  #42
Old 01-29-2013, 07:41 PM
Yes - the VSS drives a module in the dash cluster, and outputs drive speedometer, crusie control, ECU, and the "go see the dealer" service reminder. Note - on later Rovers this has been replaced by the wifi enabled dealer download of engine codes, when ever you pass within wifi range.
  #43
Old 01-31-2013, 12:43 PM
gprtech's Avatar
This brings up another point; if your VSS is good but you still have VSS type problems, it's possible there's something wrong with the instrument cluster ECU and it's outputting the wrong signals or none at all.
That would show up as cruise control problems as well as driveability issues.
  #44
Old 01-31-2013, 12:45 PM
Discolife's Avatar
I have yet to fully understand the CC function. ON GM vehicles of old it was complete seperate simple function.
  #45
Old 01-31-2013, 02:57 PM
gprtech's Avatar
Cruise control is way down on my list of things to worry about. I can't recall the last time I used it on any vehicle.
  #46
Old 01-31-2013, 06:51 PM
arthritis and a long commute will change your mind.
  #47
Old 02-01-2013, 04:17 AM
gprtech's Avatar
I've got the first. Rheumatoid Arthritis. Last year at this time I couldn't move any part of my body without pain, and I'd just suffered with regular pain for years.
Been on maximum does prednisone for a year; they haven't found anything else that works for me. Predinisone does great though, the little pain I get is less than that I had 10 years ago.
My commute is 50 minutes a day. I couldn't run the cruise control for more than 5 minutes. It's all highway, but in the NY/NJ area, it might as well be back streets.
  #48
Old 02-01-2013, 08:50 AM
NJ - so many potholes you have to change shocks at every oil change.
  #49
Old 02-04-2013, 07:15 AM
gprtech's Avatar
By the way, the VSS drives the Speedometer directly. The Speedometer itself output the signal to the ECU, cruise control and service interval counter.
As far as I'm able to determine, the module on the back of the instrument cluster provides some resistors to the fuel and temperature gauges and lights the low fuel light. It used to do a lot more, but most of the parts on it are no longer installed.
  #50
Old 02-04-2013, 08:48 AM
I stand corrected. I also believe that board may have something to ..do with the tachometer.
Quick Reply: Another VSS question....and a random
