Anti-lock en"light"enment
Old Oct 21, 2013 | 07:36 PM
FLA Rover's Avatar
Default Anti-lock en"light"enment
Today the anti lock light started to fade in and out while on the way home from work. Checked fluid and its full. Had to get one to baseball practice and another to BMX practice so have not searches threads or checked rave but it caused me to remember that when looking in the fuse box under hood I noticed that there is no 30amp fuse for the ABS valve. I've noticed no issues with braking, or system in general until light started coming on today...
Old Oct 21, 2013 | 09:16 PM
TOM R's Avatar
If that fuse is gone the ABS pump is disabled so your ABS is inop
Old Oct 22, 2013 | 07:15 AM
FLA Rover's Avatar
Which is why I'm confused by the light just now coming on.
Old Oct 22, 2013 | 07:42 AM
TOM R's Avatar
Think that is only the pump, seperate fuse for ecu?
Old Oct 22, 2013 | 08:35 AM
binvanna's Avatar
You can use a paper clip to read out the error codes. If you search, you'll get the pins on the OBDII connector and the decode sheet.
The system is worthless. Pull the fuse, and pull the bulb.
I can actually enable mine without error, but if I hit a good bump, the sensors come about 1mm out of the hub and I have to tap them back in with a mallet and a plastic punch. But even with them seated, the pump will come on at times when it makes no sense. I just consider the whole thing a curiosity of automotive genius from the past. I'm surprised it wasn't made in France.
Old Oct 22, 2013 | 12:29 PM
nuclearw's Avatar
I thought the paperclip trick was pre-obdII ...
Old Oct 22, 2013 | 04:33 PM
binvanna's Avatar
no, paper clip works on the OBDII connector for Wabco ABS on Discovery 1 and RRC. For Discovery II you need the ABS Amigo or whatever, don't know anything about D2.
Old Oct 22, 2013 | 08:55 PM
nuclearw's Avatar
Good to know... any idea the procedure?
Old Oct 23, 2013 | 06:29 PM
This is why we have a tech section.
thearmlesswonder
Dec 10, 2014 10:27 AM
targotsi
Sep 25, 2008 08:29 PM
redhotbuzz
Aug 25, 2008 08:32 PM
briauna2003
Aug 15, 2008 08:37 AM
sfxgamer
Jun 19, 2007 02:29 PM
