Atf
Old 04-18-2011, 08:15 PM
joefresso's Avatar
changed the gear lube in my transfer box yesterday. looking at doing transmission fluid. I see where to pull plug and empty, where to check level with dipstick, but where is filter and where do I put new fluid in?
Old 04-19-2011, 12:06 AM
bmxermike's Avatar
Check the tech section for the write up. The filter is inside, you need to drop the pan to get to it. You fill through the dip-stick tube.
Old 07-07-2011, 09:44 AM
AuZZZie's Avatar
OP did you flush the torque converter or just drain the pan and re-fill?
scottagnew101
08-07-2007 08:44 AM
yarddawg
06-22-2007 07:18 PM
Darover
06-04-2007 05:10 PM
jdelp
03-21-2007 06:03 PM
adowgiert
11-26-2005 01:07 PM
Quick Reply: Atf
