Auto gearbox oil temperature
Old Dec 13, 2017 | 04:31 AM
droidbrew's Avatar
4th Gear
Question Auto gearbox oil temperature
Morning all. Hope you're all good on this frosty day?
I'm a newbie so apologies if the question is a bit lame or has been asked before. I did a quick search but couldn't find what i needed so thought its best to post here.
I recently replaced the auto gearbox oil cooling lines as one had sprung a leak. As they had not been touched for a long time they had fused onto the cooler, which in turn disintegrated.
I bought a new upgrade cooler and new pipes, which are all now fitted. But i would now like to measure the temperature of the fluid in the lines and have a gauge in the cab.
I have seen there's a sensor built into one of the cooler lines, but mine is not connected, would it be a case of buying a gauge and measuring using this sensor or is this just an alarm sensor when its too hot?
My disco is an N reg 300tdi Auto ES
Old Dec 13, 2017 | 03:52 PM
DavC's Avatar
My guess is it would be the temp alarm light. You can buy a standard sender and matching gauge from somewhere like VDO and hook it up yourself
Old Dec 13, 2017 | 11:56 PM
droidbrew's Avatar
4th Gear
That's what i was thinking, but i didn't know if there was anyone on here who had done it already.
Also the sender thats screwed into the pipe is very short, and most other senders i've seen have been quite long. Like the ones you put in the sump for oil temperature.
Old Dec 16, 2017 | 12:15 AM
ricky66's Avatar
do you have a link where to buy an upgraded AT cooler? my one is all patched up and i might as well resort to replacing it with a more efficient one. TX!
bawoni
Oct 27, 2009 03:00 AM
Lofkool
Jul 12, 2007 05:15 AM
Eutychus
Dec 14, 2006 09:34 PM
pcools
Jun 14, 2006 11:34 AM
