Auxiliary fans not staying on after shutting down
So after trouble shooting my coolant system like crazy I’ve come into another problem. My AC auxiliary fans aren’t staying on after shutting the engine off. They work when I turn the AC on, the fans themselves spin but after shutting off the engine they do not stay on to bring the engine temp down. It used to do it about 4 months ago when I first got it but I didn’t realize until now.
I have a new battery, I had the alternator tested, but I don’t know much about the electrical system. I also changed the engine temp sensor recently. Anyone got any ideas for me? 97 Disco 175k v8 4.0
Here is the description from the ETM.
Condenser Fan Operation (MFI–V8)
The Condenser Fans Motors (M113, M121) on
vehicles equipped with MFI–V8 engines operate
when any of the following conditions occur:
1. Coolant temperature exceeds 100C (212F).
2. The air conditioning system is operating.
3. The Engine Control Module (ECM) (Z132)
determines that fuel temperature exceeds
70C and coolant temperature exceeds 110C
after engine shutdown. When this occurs, the
fans are turned on for approximately 10 minutes
after the engine is shut off.
Took me a few years to realize that my auxiliary fans only stay on after I switch off the engine if I leave the Air Conditioning switched on. My truck could be running very hot with the aux fans blowing but if I switch the AC off and then the truck off then the fans don't stay on after the truck is off despite being above the temp when they should be running.
I was taught to switch off everything every time when I switch off a car. Out of habit I switch off the radio, wipers if its raining, and fans. One hot day my wife drove and she doesn't switch off anything and the fans stayed on. Amazing!
Could just be a fault on my truck but the fan switch on the hvac has to be switched on for the aux fans to work. Maybe yours too?
