Bad Day
Old 06-07-2011 | 11:45 AM
adigerol77's Avatar
Originally Posted by bantham1
It is a 1998 D1. Hopefully it is not the pump. The ones I have seen are around 500 for it.
Look around for your pump, PT Schram I believe has them too. I've been pricing and I've seen anywhere between $150 - $500. Also you can buy just the actual sending unit/pump motor at a parts store and rebuild for about $70 or so. But don't quote me on that, do some searching in the threads on it.
Old 06-07-2011 | 01:28 PM
bantham1's Avatar
Would the Crank Position sensor or fuel pump relay cause this to happen? No pressure at the rail.
Old 06-07-2011 | 01:55 PM
DiscoJag's Avatar
I got my pump at Advance Auto for about $75 IIRC. It's for a Chevy Impala SS, I think the year was 1996. It's in the archives somewhere. If you go this route you do need to take the old motor out and replace it with the new one in the "frame" that lowers down into the tank.
Old 06-07-2011 | 06:07 PM
jbm6287's Avatar
Discojag saved me alot of typing. Theres plenty of threads on here about the same issue youre having, theres a really good thread on how to replace the pump somewhere on this forum too
Old 06-08-2011 | 06:29 AM
shane87's Avatar
I did have a problem with a stumble/rough idle upon start once in a while, especially when hot outside. I do not know if this could be related. No fuel at all in the rail.
If the fuel pump is getting ready to die its possible that it would lose fuel presure when shutoff and
Old 06-08-2011 | 04:15 PM
bantham1's Avatar
I have a new CPS and we will see if this works.
Old 06-08-2011 | 07:09 PM
bantham1's Avatar
Went to replace crank sensor and I cannot get the metal cover off. Also, the wires to the crank sensor are down to the bare metal. Looks like they melted. What should I do?
Old 06-08-2011 | 08:53 PM
bantham1's Avatar
I got the cover off but ended up breaking the fiberglass. Need to get a spare one now. Truck still will not start. Has spark as I go the crap sparked out of me with the plug out, but still no fuel.
yoshibond
06-13-2012 06:35 PM
seniordon
01-17-2011 01:26 PM
Spike555
05-23-2009 04:10 PM
dodge_mich
05-02-2008 10:12 PM
pureanal
07-11-2006 10:29 PM
