Bad Day
Old Jun 7, 2011 | 10:45 AM
adigerol77's Avatar
Originally Posted by bantham1
It is a 1998 D1. Hopefully it is not the pump. The ones I have seen are around 500 for it.
Look around for your pump, PT Schram I believe has them too. I've been pricing and I've seen anywhere between $150 - $500. Also you can buy just the actual sending unit/pump motor at a parts store and rebuild for about $70 or so. But don't quote me on that, do some searching in the threads on it.
Old Jun 7, 2011 | 12:28 PM
bantham1's Avatar
Would the Crank Position sensor or fuel pump relay cause this to happen? No pressure at the rail.
Old Jun 7, 2011 | 12:55 PM
DiscoJag's Avatar
I got my pump at Advance Auto for about $75 IIRC. It's for a Chevy Impala SS, I think the year was 1996. It's in the archives somewhere. If you go this route you do need to take the old motor out and replace it with the new one in the "frame" that lowers down into the tank.
Old Jun 7, 2011 | 05:07 PM
jbm6287's Avatar
Discojag saved me alot of typing. Theres plenty of threads on here about the same issue youre having, theres a really good thread on how to replace the pump somewhere on this forum too
Old Jun 8, 2011 | 05:29 AM
shane87's Avatar
I did have a problem with a stumble/rough idle upon start once in a while, especially when hot outside. I do not know if this could be related. No fuel at all in the rail.
If the fuel pump is getting ready to die its possible that it would lose fuel presure when shutoff and
Old Jun 8, 2011 | 03:15 PM
bantham1's Avatar
I have a new CPS and we will see if this works.
Old Jun 8, 2011 | 06:09 PM
bantham1's Avatar
Went to replace crank sensor and I cannot get the metal cover off. Also, the wires to the crank sensor are down to the bare metal. Looks like they melted. What should I do?
Old Jun 8, 2011 | 07:53 PM
bantham1's Avatar
I got the cover off but ended up breaking the fiberglass. Need to get a spare one now. Truck still will not start. Has spark as I go the crap sparked out of me with the plug out, but still no fuel.
yoshibond
Jun 13, 2012 05:35 PM
seniordon
Jan 17, 2011 12:26 PM
Spike555
May 23, 2009 03:10 PM
dodge_mich
May 2, 2008 09:12 PM
pureanal
Jul 11, 2006 09:29 PM
