bad idling
Old Nov 12, 2011 | 10:42 PM
pedronz's Avatar
Default bad idling
hi all
My 94 disco started to idle erratacally and was slowly getting worse, also another issue was at about 3500 rpm the power deleivery was a surge of power, i was seriously thinking the dreaded cam lobe had worn off,
i put a vacumm gauge onto the motor and had about 17" vac, we wound the dizzy around to max vac and then retarded it about 1" of vac, i then went for a test drive, more power but still had a surge and also detonation, i drove home thinking about the symptoms, and came up with the MAF being dirty, a ford 302 i have has had the same symptoms, any way got it home, pulled the MAF out and apart, the hot wire had a little bit of crud on it, i sprayed it with brakleen and then blew it out with compressed air and reassembled it, and then put it back in, the change was staggering, the idle is now rock solid, the drive is loads smoother, no surging, runs very very nice now, have had no low idle issues since, starts eaiser, is not as rich when cold.
i had pulled the IAC valve out and cleaned and lubed that but had absoultley no change, i got the plunger out by having the motor idling and unscrewed the IAC valve, as i wound it out the plunger wound in to compensate, eventaully it fell out, getting it back in was KOEO a few times to wind in in.
Cheers Pedronz
Old Nov 12, 2011 | 10:47 PM
Thank you very much for this info!!!!!!
Old Nov 13, 2011 | 07:54 PM
Would add that working on the hot wire MAF sensor is best done cold, brake parts cleaner cools things off quickly, like putting a hot light bulb filamant in ice water, extreme temp change could kill MAF sensor.
Old Nov 13, 2011 | 09:20 PM
Danny Lee 97 Disco's Avatar
Use CRC MAF Cleaner for great results.
Old Nov 14, 2011 | 01:51 AM
pedronz's Avatar
brakleen works quite well as well, not sure i have seen maf cleaner over here, as for the hot wire I would think unless the ign is on it would be well cool enough to spray, once you get it off the motor and strip it.
cheers
Pedronz
richardgatekeeper
Jul 25, 2007 05:58 PM
eriqcharlz
Jul 3, 2007 09:30 AM
EVN137
May 30, 2007 07:24 PM
2tall4u
Jul 26, 2006 05:50 PM
LANDY1998
Freelander
Sep 18, 2005 09:35 PM
