Bad Starter?
Old Sep 6, 2010 | 10:43 AM
98roverguy's Avatar
Default Bad Starter?
Truck has left me stranded for the second time this summer far from home. First was the fuel pump. This time I pulled up to a gas station, fill up and now it won't even crank. So I check the battery, connections which were both good. For the heck of it, I even hooked it up to a battery jumper and no go.
All you here is a click from the starter. I am thinking it is the starter, or solenoid, which I believe is attached to the starter. For this reason I had it towed to a shop because if it is the starter I don't have the time or energy to do it in my apartment complex (it looks like a real pain in the a$$).
Will likely get a diagnosis Tuesday but thought I would pick your brains if you felt it could be something else. I personally don't recall starters failing very often on these trucks but I could be wrong.
Also, I am tired of being stranded with no starts and my AAA towing miles are all used up. What other items can I replace as I approach the 100,000 mile marker that are likely to fail so i can be proactive?
I have replaced the fuel pump and fuel relay (relay as preventative only - did not fail) and now looks like the starter. Anything else you would recommend I change out? I am tired of being stranded and frankly it is becoming embarrassing.
Old Sep 6, 2010 | 11:06 AM
Could be a corroded cable on the starter.
Have you read through this?
https://landroverforums.com/forum/sh...ad.php?t=33418
Old Sep 6, 2010 | 11:24 AM
98roverguy's Avatar
Thanks for the link Spike. Going to look into one of those Nipon Denso starters as well as a new positive battery cable from AB.
Going to have them install the new cable with the starter just in case. http://www.roverparts.com/Parts/AMR4803AB.cfm
Old Sep 6, 2010 | 06:11 PM
Danny Lee 97 Disco's Avatar
Cable is most likely candidate, I would replace it before the starter. i bought a used starter, mine turned out to be the cable connection from starter to frame.
Old Sep 7, 2010 | 08:04 AM
okdiscoguy's Avatar
one thing to keep in mind is your park switch. Sometimes if it isn't all the way up, it will just give a tick. Did you try to start it in neutral too? Just another thought...
Old Sep 9, 2010 | 09:11 AM
98roverguy's Avatar
Just thought I would follow up. It turns out the positive cable to the starter had corroded significantly internally. I cut a cross section of it and it almost turned to dust.
Replaced that and she starts up great. Starter, battery, and alternator were all tested and found to be normal. Also cleaned contacts of the negative cable from the starter to the frame.
Thanks.
Old Sep 9, 2010 | 09:14 AM
98roverguy's Avatar
That had occurred to me as well. Ya I had tried to start it in Neutral. As always thanks for the input OKDiscoguy and everyone else for the thoughts/help.
Gimebakmybulits
Jul 14, 2014 05:57 PM
johnkbl
Apr 23, 2012 07:49 PM
Sunshine
May 12, 2008 08:25 PM
Phototone
Apr 7, 2008 12:01 PM
drhunter
May 10, 2007 07:29 AM
