Battery Tiedown Advice Needed
Old Feb 4, 2018 | 02:00 PM
colemtd's Avatar
Default Battery Tiedown Advice Needed
Hi All, the dealership doesn't sell the tiedown kit for this model anymore, so can anyone tell me where I can purchase the bracket that goes across the battery and what length the J hooks need to be?
Or if someone has a link to a kit or all the accessories needed that would be great as well..
Old Feb 4, 2018 | 04:44 PM
stillruns's Avatar
Check your local LQK. I bet a DII bracket would fit as well.
Old Feb 4, 2018 | 05:18 PM
OverRover's Avatar
Here are the OE part numbers, but once you search them (RN, etc) the prices are somewhat shocking.
The best bet for OE bits is PM abran or paul grant for a used setup.
OR get a universal set from Advance Auto or AutoZone and cut/bend the short J hook to length. It's very simple with a hacksaw and a pliers. They also sell a bracket kit that has a rubber strap and it sucks.
I've used the adjustable plastic bracket (see above) a few times and it works well.
Good Luck!
Old Feb 4, 2018 | 07:11 PM
jimvw57's Avatar
I added a nylon strap with a j hook on one end and tied it up behind the headlight to the front header. It is not going anywhere and the nylon is good against the acid
nateandnikki
Jul 2, 2013 06:38 AM
xoo00oox
Jan 11, 2013 06:23 AM
The Cisco Kid
Apr 19, 2010 09:03 PM
algeroth79
May 2, 2006 10:59 AM
arrkerr
Dec 14, 2005 10:06 AM
