Because I'm too cheap to buy a new prop shaft
Old Mar 3, 2012 | 11:01 AM
Danny Lee 97 Disco's Avatar
Lucas now sells Liquid Turd Polish in bulk for those new owners who may need large quantities at a good price.
5 Gallon minimum purchase, or free shipping on the 55 gallon drum.
Old Mar 3, 2012 | 11:27 AM
smoker's Avatar
I'm too cheap to buy turd polish, I make my own.
That's good info on the shafts, I had no idea they switched over. I'm very much a Rover noob, but I know what it's like to be on the other end as well... I'm just glad there isn't noob-bashing here like there is on the VW/Audi forums. Y'all seem very civilized.
Old Mar 3, 2012 | 11:52 AM
jafir's Avatar
Also, there is this one:
Lucky8 Llc. - Take the road less traveled...
It looks to be new.
Old Mar 3, 2012 | 12:29 PM
Originally Posted by Danny Lee 97 Disco
Land Rover made a change somewhere along the way that did away with the rotoflex and changed over to the rear u-joints as well. It uses a four bolt flange rather than a three bolt flange. It is true that new "upgraded" driveshafts are available like you said, but you can also go used if you find one from a 98DI or possibly mid 97, I do not know the exact change over. LR was known to make changes whenever they chose to and tracked them by VIN #.
My used 98 d/s and required parts was roughly $100. D/s was sourced locally for like $50 or so, then flange and new seal accounted for the rest.
Paul and PT both provide great prices on used parts, so as a newbie, it is good to check with them when needing parts which is almost constant for a while.
Late '97 through '99 DI's switched to a 4 u-joint set up, WAY better than the roto coupler.
BUT they went back to it with the DII.
Old Mar 3, 2012 | 01:36 PM
slanginsanjuan's Avatar
that Lucky8 deal looks very good and they're one of the reputable ones. the info (greasable?) and photo isn't very good.
Old Mar 3, 2012 | 01:42 PM
If you enlarge the picture...(you can see the grease zerks)
Old Mar 3, 2012 | 01:53 PM
ptschram's Avatar
I do not actively market used parts. There are several fine gentlemen in that field of endeavor and I do not wish to step on their toes.
New parts? I'm your man. Used stuff, Paul Grant, Marty Powell, Will Tillery, Joel Mercer are just a few off the top of my head.
Old Mar 3, 2012 | 02:42 PM
As a frequent "partz vulture" that flys low in the junk yard; I would point out that in most junkyards the vehicles are moved about by a large fork lift, and frequently the drive shafts are dented and bent in the process. Buying new, or from a dismantler (parts guy that removes it by hand) would be preferred over the salvage yard.
Old Mar 3, 2012 | 02:54 PM
PT, thanks for the clarification. Do you have a website or other means of seeing what you have availabvlke? I know I have seen yoiur name on here and other places but have not yet had occasion to deal with you.
The place I deal with locally brings their vehicles into a former steel mill building along the river in Pittsburgh. They go ahead and remove the major items and place them into inventory and then crush the vehicle and recycle the metals. It is quite different than a typical junkyard.
But one always takes a chance on most used parts. I have done well with both Will Tillery and Paul Grant.
Old Mar 3, 2012 | 03:22 PM
ptschram's Avatar
If the planets ever align correctly, I'll have a shopping cart. for the time being, unless you have an armored vehicle or are otherwise prohibited from buying due to CBP/DHS import/export restrictions, and it is still available from Land Rover or other aftermarket sources, I can get what you need.
I stock popular parts for Classics/DIIs/200 and 300 TDis.
