Best Diagnostic Scanner for D1
Old 05-18-2021, 09:55 PM
nzajg's Avatar
Default Best Diagnostic Scanner for D1
Could anyone advise on the OBDII device required to diagnose a 1995 - 96 Discover V8. There are numerous options available, but normally there is usually one that is preferred as the best option. I have an intermittent cutout fault with the Vehicle Speed Sensor circuit. I've had variant local advice, some saying a scanner will identify the fault, others advising the contrary. Many thanks.
Old 05-19-2021, 07:58 AM
logan_gibson's Avatar
95 isn't OBD2 truck,
FaultMate is going to be the most advanced unit you can readily buy, get your wallet ready.
Old 05-19-2021, 04:11 PM
nzajg's Avatar
I'm getting conflicting advice, some say the D1 has a limited OBD2 diagnostic facility, some say not. How do you identify whether or whether not?
Old 05-19-2021, 05:07 PM
WaltNYC's Avatar
nzajg.... I always forget that you have a 1995 and therefore give you advice that doesn't apply. Your truck will not have OBDII capabilities. Sorry if I was the source of confusion.
logan_gibson (05-19-2021)
Old 05-19-2021, 06:59 PM
OBD2 port, bottom of the dash infront of the accelerator pedal.
95 trucks run a Lucas system, Faultmate can still read it, but not do a whole lot. Rovergauge I believe is the software that lets you modify it a bit more.
You connect to the 5pin lucas connector for this. Faultmate would just need a different license to do that, as well as the right connectors.
I believe you can also install the diagnostic display under the seat, and get some codes from that. Pretty cheaply, I have one for sale.
Old 05-23-2021, 12:25 AM
JohnZo's Avatar
Maybe this will help clarify the question. My 96 GEMS engine uses OBD2. I think this was the first year for Land Rover OBD2, as all new automobiles sold in the USA required it that year, but some brands had it sooner. I use an OBDLink LX bluetooth adapter, and pair it with Torque software I run on a Samsung tablet. My last update with Torque cost all of five dollars. It shows everything, real time fuel trims, O2 signals, etc. I can wander around the truck while its on. I bought the OBDLink device after using a cheap $10 ebay unit for a few years. I have not really noticed any difference in function, but the OBDLink device has been a bit easier to use, with legitimate corporate backing, so it cost more.
My 94 runs a Lucas system that produces two digit codes on a module under the passenger seat if the Check Engine Light is activated. At some point, if I need to check sensors, I'll be using a multimeter. OBD2 is way better. This truck also has a diagnostic connector for TestBook behind the RH side foot panel, but that was for dealer service only, I think.
Hope this helps.
krammark
09-15-2016 10:15 PM
chavhater
01-30-2013 04:04 AM
hh65flyer
11-30-2011 05:40 PM
sharp
02-05-2009 09:11 PM
Cleggy
03-04-2006 06:34 AM
Quick Reply: Best Diagnostic Scanner for D1
