Beyond total embarassment...
Old Aug 13, 2013 | 06:39 PM
  #31
dusty1's Avatar
An air chisel or some type of vibration applied might prove helpful. I've done the air chisel on a terribly rusted hub to help break it loose
Old Aug 13, 2013 | 08:36 PM
  #32
TOM R's Avatar
There is a big steel pin like 3/4 inch dia, shifter is hooked to it , it slides left and right, one side you can see sticking out of the shift housing hooked to linkage you see, this pin in mine was heavy rusted so the pin could not go left through the shift housing it is a everything tight fit, wish I had pics
Old Aug 13, 2013 | 09:27 PM
  #33
NabisOne's Avatar
i had nearly the same experience as Tom, but mine wasn't really rusted. Whatever grease had been put in the CDL had hardened and caused it to be inoperable. Its a fairly easy job to pull the console and remove the CDL. I ended up taking mine completely apart and sealing it with a piece of rubber to keep the junk out. Search for Danny Lee's thread on this for console removal.
FLA Rover
Jul 22, 2013 12:11 PM
CANAMDiscovery
Dec 19, 2012 09:40 AM
sonya2020
Oct 19, 2012 07:02 AM
jrm123180
Aug 15, 2010 05:23 PM
kean
Mar 6, 2009 05:06 PM
