Blower mystery
![Question](https://landroverforums.com/forum/images/icons/icon5.gif)
Hey guys,
This one has got me scratching my head.
Heater fan had only the usual #1 & #4 selections blowing air.
Then one day she upright quit.
Understandable so I got the blower motor resistor.
Nothing changed, but I did hear a faint click come from the blower relay under the dash. Got one of those & put it in. Nothing still but a click from it in all the selections from 1 to 4.
Thoughts?
Fuse is good because I can hear power *click* to the relay.
Both new original LR parts.
Ideas?
ANY info be great as it's -21c with our onset of winter here in Canada.
~Christian~
1998 LR D1 197,891kms
Thoughts?
Ideas?
~Christian~
Sounds to me like your 1,2,3,4 blower speed selector is possibly INOP. Mine occasionally will stop blowing on position 4 if I hit a bump. They're not very cheap if you look for a D1 unit, but I'm 99% sure a D2 rear AC speed switch uses the same slider switch and you can find those all day long on Ebay.
XCELLER8 (12-21-2016)
yup...the switches get corroded and then the contacts start to arc inside the switch...if it's not damaged too bad yet you may be able to resurect it for a while by shooting some WD40 in the switch....it wont hurt anything and might clean it enough to help
thanks Best4x4 ...I didnt know about the D2 rear a/c switch....I'm getting ready to part my D2...
Yeah I had a D2 that I was working on for a friend. They had gone and bought a completely new rear AC Control for their D2 just because theirs no longer lit up. It was the first time I'd had one in my hand so I inspected it and found out of coarse the bulb could be replaced. Then I noticed it had the same slider as a D1 so I gutted it (didn't have a D2 with rear AC at the time) and sure enough the actual slider switch is exactly the same part!
It'll take a little finesse to get your old D1 slider assembly out but it can be done!
