Blower mystery
Old Dec 21, 2016 | 08:09 PM
ourplacenorth's Avatar
6th Gear
Question Blower mystery
Hey guys,
This one has got me scratching my head.
Heater fan had only the usual #1 & #4 selections blowing air.
Then one day she upright quit.
Understandable so I got the blower motor resistor.
Nothing changed, but I did hear a faint click come from the blower relay under the dash. Got one of those & put it in. Nothing still but a click from it in all the selections from 1 to 4.
Thoughts?
Fuse is good because I can hear power *click* to the relay.
Both new original LR parts.
Ideas?
ANY info be great as it's -21c with our onset of winter here in Canada.
~Christian~
1998 LR D1 197,891kms
Old Dec 21, 2016 | 09:06 PM
Best4x4's Avatar
Sounds to me like your 1,2,3,4 blower speed selector is possibly INOP. Mine occasionally will stop blowing on position 4 if I hit a bump. They're not very cheap if you look for a D1 unit, but I'm 99% sure a D2 rear AC speed switch uses the same slider switch and you can find those all day long on Ebay.
Old Dec 21, 2016 | 10:14 PM
XCELLER8's Avatar
yup...the switches get corroded and then the contacts start to arc inside the switch...if it's not damaged too bad yet you may be able to resurect it for a while by shooting some WD40 in the switch....it wont hurt anything and might clean it enough to help
thanks Best4x4 ...I didnt know about the D2 rear a/c switch....I'm getting ready to part my D2...
Old Dec 21, 2016 | 10:26 PM
Best4x4's Avatar
Yeah I had a D2 that I was working on for a friend. They had gone and bought a completely new rear AC Control for their D2 just because theirs no longer lit up. It was the first time I'd had one in my hand so I inspected it and found out of coarse the bulb could be replaced. Then I noticed it had the same slider as a D1 so I gutted it (didn't have a D2 with rear AC at the time) and sure enough the actual slider switch is exactly the same part!
It'll take a little finesse to get your old D1 slider assembly out but it can be done!
Old Dec 22, 2016 | 08:32 AM
Paul Grant's Avatar
If all else fails, I have used HVAC control units in stock that all tested good and come with a warranty.
Old Dec 22, 2016 | 10:39 AM
jimvw57's Avatar
The blower motor circuit draws a LOT of amperage. I had a replacement switch on it's way and installed a couple of jumper wires temporarily. They got awfully hot driving to work and back. I even changed to larger wires just in case. The circuit does use a 50 amp fuse.
Old Dec 22, 2016 | 11:42 AM
JUKE179r's Avatar
Spray some electronic terminal/contact cleaner in it.
I would never use WD40 on electronics since it leaves oil residue.
Old Dec 24, 2016 | 10:23 AM
jimvw57's Avatar
The slide switch is not easily accessible from the outside of the dash, I doubt that spraying anything in without taking the console apart would make much difference.
Old Dec 24, 2016 | 10:08 PM
XCELLER8's Avatar
sorry boys, but it worked for me.............
Old Dec 24, 2016 | 11:34 PM
jimvw57's Avatar
whatever works!!
vonrock
Jan 4, 2016 05:55 PM
jasmin
Off Topic
Feb 24, 2007 11:38 AM
chrisusvi
Feb 12, 2007 11:32 AM
alex of minnesota
Dec 21, 2006 09:40 AM
meyersd
Oct 9, 2006 09:21 PM
