Brake fluid
Old Apr 12, 2011 | 02:51 PM
DaddyBear's Avatar
7th Gear
Default Brake fluid
I am replacing my master cylinder and reservoir tank. When I ordered the part from AB they told me that Castrol brand brake fluid should be all that's ever used in rovers. Can anyone confirm this or was it just a sales pitch?
Old Apr 12, 2011 | 03:26 PM
groundandpound's Avatar
As long as it is DOT 4 (or meets the requirements for DOT 4) it should not matter....I see NOTHING in the RAVE about a specific brand...
I don't use Castrol, and don't have any issues. Further, the brand I buy is DOT 3/4 combination.
Old Apr 12, 2011 | 03:50 PM
DaddyBear's Avatar
7th Gear
Thank you for the response. I have also been using the DOT 3/4.
Old Apr 12, 2011 | 03:56 PM
DaddyBear's Avatar
7th Gear
Old Apr 12, 2011 | 03:57 PM
No problem - looks like I am just up the road from you!
When I was checking on the same question as you, I did some reading/research which led me to my comments to you.
Also, in the FWIW column, a 32oz bottle of Castrol from AB is almost $10 (BEFORE shipping!) whereas the "3/4" combo that I buy was under $2 for the 32oz bottle.
Initially I was using the Castrol because that was all I could find - but have had no negative side effects from switching.
Old Apr 12, 2011 | 08:33 PM
Your Rover came with all Castrol fluids in it because it is a UK company.
But as long as you use a low moisture absorbsion brake fluid you are fine with any brand.
Athana
Jun 8, 2019 10:23 AM
Rolltop
May 5, 2014 09:17 AM
1998DiscoverySE
Jul 20, 2012 08:02 PM
LRScott
Mar 4, 2009 08:39 AM
flyingalexf68
May 9, 2006 01:51 PM
