Brake Light Issues
So ive tried searching what could be causing this and couldnt find anything on my specfic topic.
The brake lights on the body of the truck do not come on at all, or the brake lamps on the bumper. My upper 3rd brake light works, my taillamps work. my reverse lights work, my rear foglamps work, all turn signals work.
All simple solutions have been checked, no loose connections, no bad bulbs, and no blown fuses.
and if it was the brake light switch or short wouldnt the upper 3rd not work also?
Im just tired of using my rear foglamps in sync with the push of the pedal for brakelights.
Thanks, Brad
Thanks, Brad
Agreed on brake light switch. SeeRAVE ETM page Z5 - #23, which is locations for connector C415 and C406 and C400. These are associated with the stop lights anjd located inside the body in the space behind and below the cargo area light (beside hinge side of door). There is a pop off panel.
ok i found all but c415. they all look to be in decent shape, the one hooked up to the taillamps is fine, the trailer aux. socket isnt hooked up to anything it just has a rubber cap, i still dont know what could be causing by brakelamps on the body not to work yet my upper one works fine
UPDATE, YAY FIRE! ok so i might have found the problem, i have yet to check the drivers side one but the passenger one shows what appears to be fire damage. see pics
It looks like it shorted if anyone has anyother ideas let me know.
Im headed back out to the driveway to test to see if it even works anymore.
That is definitely an overheat condition. I seem to recall seeing something about the taillights tending to short out on these but do not recall any specific details. Did you try a search on brake lights?
yes i did try seaching, I finally just took at to the wrong place, the bulbs that were in there were different from the ones listed on the socket plug, and those numbers were all different from the stores computer.
I do recall that people suffered damage from the trailer plugs, don't know if that is associated with your problem or not. If it were me, I would call Paul Grant/Will Tillery and see if they have any tail light sockets available and go ahead and cut off those screwed up ones and replace them. Can't hurt.
mine were like that, same thing I had no brake lights but the third eye was ok. I am somewhat ashamed to admit that I fixed them with tinfoil temporarily which has become permanent as it functions quite well, at least until it stops working again, i guess.
i
i
problem fixed, PO had just thrown some random bulbs in , they were drawing to much. That caused the bulbs to over heat or short out the circut or something and create enough heat to burn and melt the plastic....Solution clean off metal surfaces, replace with new correct bulbs and now I have all my brake lights again. for now.
