Brake lights stuck on / no cruise control
Both the brake light and cruise control cancel switches are mounted on the brake pedal. Its possible that they both went bad at the same time but I doubt it. Its also possible that the cruise not working is completely unrelated to the brake lights. Most D1's don't have working cruise control.
Its probably best to contort your body and look to see whats going on by your brake pedal.
My Jeep Gnd Cherokee sometimes leaves the brake lights on and I have to pull up on the brake pedal to turn them off - had a couple of dead battery times before I noticed the cause of the drain. If your brake pedal is not coming up far enough it could cause both symptoms.
Evan5291
11-21-2017 07:59 AM
southfloridadiscoII
06-28-2009 11:03 PM
Robmcin
04-06-2009 09:26 AM
