Brake Proportioning Valve
Old Mar 20, 2011 | 11:05 PM
kenk's Avatar
Default Brake Proportioning Valve
Do D1's have one? I ran into an odd problem. Hooked up my small utility trailer w/my 4-wheeler in it(maybe 1k lbs total).
And by time I got to my riding spot, my rear brakes were litteraly smoking hot. After riding, went home, same thing.
Thought maybe they were dragging. Unhooked the trailer, went for a ride, no overheating rear brakes??
Old Mar 21, 2011 | 01:33 AM
antichrist's Avatar
Yes, it's on the inner wheel well under the MC.
Sounds like you definitely have a problem. I've towed my heavy flatbed trailer a number of times without the trailer brakes and not had any issues at all.
Old Mar 21, 2011 | 10:11 AM
kenk's Avatar
Thank you. Now, if my understanding is correct, that valve sends more braking power to the rear wheels when it senses a load in the back(lower rear end than normal)?
And I'm sure it's not a fix anyone would recommend, but I could just by-pass it? Or does it actually reduce pressure in "normal" mode?
Old Apr 22, 2018 | 03:32 PM
dragonpen1's Avatar
Default Mine did the same on front actually caught fire on left wheel (grease ?)
Front brakes did same for me so hot seals failed on one front caliper. Changed calipers and hoses front. No fluid to front so changed master cylinder- now just left front has no pressure - is not the hose. Anybody any ideas. Prporining valve?
Old Apr 22, 2018 | 09:32 PM
XCELLER8's Avatar
proportioning valve is there only to reduce the amount of pressure to the rear wheels ...no real "sensing" involved....just a general reduction in pressure to keep the rear wheels from skidding.....most brake systems put the majority of pressure to the front wheels...the M/C likely puts out equall pressure front/rear so thus the need for the valve....the ABS does the rest( if it works)
Old Apr 23, 2018 | 09:03 AM
dragonpen1's Avatar
Default What could cause no pressure to the left front wheel- new hase was fitted.
No pressure to left front wheel. New hase fitted to new caliper- ABS jumped to 12 v to turn mechanism- still no pressure to left front
Old Apr 23, 2018 | 10:18 PM
XCELLER8's Avatar
well....first try bleeding the left front caliper....do you have fluid / pressure when you do that ?....if so, I would suspect a stuck caliper
christiansmith6
Nov 3, 2014 10:29 PM
wheelgarage
Jun 9, 2012 03:17 AM
Kimberl563
Jul 11, 2011 01:21 PM
zracin
Jul 7, 2011 12:55 PM
majrmike
Oct 9, 2007 03:13 PM
