Brake Switch bad- stuck in Park - Need to move it
Old Nov 19, 2024 | 07:02 PM
whiskeynipple0088's Avatar
Default Brake Switch bad- stuck in Park - Need to move it
So yeah my brake switch is not letting me shift it out of park - worked fine this morning.
I have the switch out and tested it - one side is always on (pretty sure thats not right). I also tried with the switch removed and no change.
Is there a way to jump the connection to get it out of park?
Would like to avoid removing the center console.
Its blocking my other vehicle (that works)
Old Nov 19, 2024 | 07:12 PM
Nvmd - think I found what I need here
https://landroverforums.com/forum/di...t-dust-118190/
Old Nov 19, 2024 | 09:32 PM
disco96sd's Avatar
While you are down there replace the cruise control switch too -
Old Nov 20, 2024 | 06:49 AM
hmm maybe thats why I couldnt get CC to work years ago.........
Idk though, if I fix all the minor issues..... isnt it a rule that something major breaks - haha
Eitherway can confirm JohnZo's post I linked works on my 98 v8 - 'note to self' keep paper clips in the glove box!
Old Nov 20, 2024 | 07:42 AM
jastutte's Avatar
do you have LED bulbs in your brake lights? if so, that will also not allow the CC to work.
Old Nov 20, 2024 | 09:12 AM
jimvw57's Avatar
A trick I learned a few years back when my brake switch quitand I was far from home was to hook the 3rd brakelightwire into the rear defrosterconnection. turning on the rear defroster will allow you to shift out of park...
Old Nov 20, 2024 | 03:40 PM
I do not but that is real good info
Old Nov 20, 2024 | 03:44 PM
Ok thats trick - would have never thought of that.
whats interesting is theres no solenoid release by the shifter like say a toyota - makes me wonder, if it is to be towed without the key present/or has a bad brake switch..... do they disconnect the driveshaft?
Old Nov 20, 2024 | 06:36 PM
jimvw57's Avatar
Locally around here, they pull it on a flatbed...
suzukisam
Mar 27, 2020 06:55 PM
DiscoGatorSeriesI
Jun 3, 2018 02:25 PM
handsome rob
May 12, 2017 10:10 AM
s10lowrider1994
Jan 19, 2013 09:54 PM
discolucy
Oct 28, 2009 12:43 PM
