Sponsored by: CARiD
Help-Won't come out of park.
Old Oct 24, 2009 | 11:37 PM
discolucy's Avatar
5th Gear
Default Help-Won't come out of park.
I have a 97 disco and for the last week when I try and put it in drive it wont come out of park, the shifter just won't move. After trying several times it would finally go in drive. Now for the last two days I've been trying to get it out of park with no luck. Any ideas?
Old Oct 25, 2009 | 02:01 PM
You probably don't have any brakes lights either and if that is the case, you need to replace your brake switch up by the brake pedal.
Old Oct 27, 2009 | 04:26 PM
hlc's Avatar
hlc
4th Gear
the shifter get a signal from the brake switch letting it know that the brakes are applied before it will shift. Check the function of the brake switch. u may have a release that u can push to manually release the shifter.
Old Oct 28, 2009 | 12:43 PM
discolucy's Avatar
5th Gear
You're right brake lights don't work. I found the brake switch and was able to get it out of park. Is the switch supposed to be mounted somewhere because right now its just kind of hanging there?
Coolpines
Dec 11, 2014 07:35 AM
FrFghtrBRET
Dec 12, 2011 07:44 AM
Cosmic88
Mar 9, 2011 06:53 AM
sfxgamer
Dec 24, 2010 12:58 PM
josemex
Dec 20, 2009 08:38 PM
