brakes too much -
Old Aug 20, 2012 | 11:56 PM
ssparrow's Avatar
Default brakes too much -
i replaced my master brake cylinder unit (Autozone aftermarket) and now when the engine runs for a while the brakes start to engage without me pressing the pedal - pedal becomes stiff as a rock - when I turn the disco off, the brakes let loose. Details - 1997 disco SD - gas engine - could it be the booster or?
Old Aug 21, 2012 | 07:10 AM
DiscoJag's Avatar
Aftermarket master cylinders do not work on these trucks - at least that's what a lot of people have said on this forum. I have not replaced mine yet, but I'm sure someone else with first hand experience will chime in.
Old Aug 21, 2012 | 09:34 AM
Mightym's Avatar
I just replaced mine with one from autozone also, and have the exact same thing happening. What is the recommended fix if the autozone unit won't work. What brand should I look for, or where should I get one.
Old Aug 21, 2012 | 09:48 AM
ssparrow's Avatar
Thanks for the reply - - Interesting - TRW (master brake brand) claims the unit is as good or better than the original. I have a feeling it's not the master because when the engine is turned off. the issue goes away... I'm new so I am open to any suggestion.
Old Aug 21, 2012 | 10:22 AM
ssparrow's Avatar
Hi - If you had the same issues with this aftermarket part, we may be on to something - I may order a TRW brand unit from British Pacific on line - they are on the west coast so I should get the unit in a few days. it's about $100 more but if it's the right part, what can a person do??? Rovers cost money! LOL! thanks
Old Aug 21, 2012 | 10:44 AM
Danny Lee 97 Disco's Avatar
There is a list of Rover Suppliers on a sticky Check it Out!
I look at Rover's North, Atlntic British and a limited number of others.
Of course we all know everything on the Internet is True, they are not allowed to put anything but the Truth on there... I read that on the Internet.
Old Aug 21, 2012 | 11:28 AM
Mightym's Avatar
The brand that I got at autozone was Fenco, I believe. Napa can get an A1/Cardone, but has to be ordered and not much cheaper that ordering from British Pacific.
Old Aug 21, 2012 | 12:11 PM
jafir's Avatar
Any chance the older master was leaking into the booster?
Old Aug 21, 2012 | 12:47 PM
ssparrow's Avatar
I ordered a new master today - should be here in a few days - From what I have learned on this and other forums, I feel confident that this will resolve my issues - lesson learned - buy from a "Rovers only" parts house -
Old Aug 21, 2012 | 12:51 PM
ssparrow's Avatar
the connection between the reservoir and the master had a very bad leak - no fluid got into the booster. The brakes actually worked great but the constant flow of brake fluid was the issue.
