Brand new at this, have a few questions about my new ride!
Old May 27, 2015 | 04:40 PM
Vigo's Avatar
Just gabbed the fan and checked for movement. Fan/pully has noticeable play. Looks like I found where to start taking things apart at... Thanks for the tip!
Old May 28, 2015 | 02:30 AM
loanrangie's Avatar
Check your balancer, they are known to flog out the keyway and worse case fall off.
I had one slip off the crank 200m from home, walked home got a spare crank bolt and i was off again in 30mins.
Old May 29, 2015 | 06:55 AM
Fenix's Avatar
I had the same issue with engine knock and think it was temperature related. I replaced the water pump with a HD version, fan clutch, radiator, rover thermostat, reservoir cap, electric fans, and changed to G5 coolant making sure to bleed the air out of the system. I also did an oil system flush and started using 20W -50 and have no cooling issues or engine knock.
kfx4001442
Jan 24, 2012 08:58 AM
Turbo74
May 6, 2010 12:57 PM
davecason
Jan 27, 2008 07:38 PM
briman42487
Oct 14, 2007 09:47 AM
wiseguy
Mar 18, 2007 09:36 AM
