Broken shock replacement
Have got some terrafirma tf121 rear shocks to replace broken ones , does anyone know if they go on the top mounting pin with no bushes or washers? Thanks in advance .
the shock comes with 2 sets of washers 2 bushes and another 2 washers and bushes attached to the bottom .
I have these installed on my ‘97 with simply a washer and nut on the outside, no washer on the inside. However, mine are the +2 inch taller shocks. With these they did not supply a washer, and the instructions stated a washer would “wear out the shocks faster”. I found it weird to just have a nut tightened up against a rubber bushing so I just used the washer from my old shock. Dunno if that helps!
HI Rover
10-19-2014 11:51 PM
