Broken shock replacement
Old Nov 10, 2021 | 11:55 AM
Birminghamrover's Avatar
Default Broken shock replacement
Have got some terrafirma tf121 rear shocks to replace broken ones , does anyone know if they go on the top mounting pin with no bushes or washers? Thanks in advance .
the shock comes with 2 sets of washers 2 bushes and another 2 washers and bushes attached to the bottom .
Old Nov 11, 2021 | 08:57 AM
logan_gibson's Avatar
Just a washer and nut for the top mount.
Old Nov 11, 2021 | 08:29 PM
ononomos's Avatar
I have these installed on my ‘97 with simply a washer and nut on the outside, no washer on the inside. However, mine are the +2 inch taller shocks. With these they did not supply a washer, and the instructions stated a washer would “wear out the shocks faster”. I found it weird to just have a nut tightened up against a rubber bushing so I just used the washer from my old shock. Dunno if that helps!
Old Nov 13, 2021 | 03:06 AM
Yes that does help . Its confusing as the instructions show top mount with washers either side . I think the warning about premature wear is about the cup that is welded to the bottom , i think it should be removed to install the new ones .
Old Nov 21, 2021 | 10:43 PM
reboot's Avatar
just seeing this, late reply, I believe the washer on the top with the nut as logan_gibson says, is actually the original nut and washer. The washer is 'thicker' . They must have sent you extra bushes and washers. I replaced mine with the Terrafirma a few months ago too.
Old Nov 22, 2021 | 11:25 AM
Thanks all! Went with the washer off the old shocks . Looks nice , shame its all hidden behind my tractor tyres 😂
outono
Oct 12, 2020 05:45 PM
Alex_M
Sep 24, 2018 11:10 PM
vishrb
Jul 29, 2017 06:47 PM
HI Rover
Oct 19, 2014 11:51 PM
sleepercoupe
Apr 21, 2011 12:12 PM
