Brunei Disco Onwards and Upwards
Old Nov 24, 2011 | 12:08 AM
Havoc556's Avatar
Default Brunei Disco Onwards and Upwards
Hello all,
Just thought would post an update on what I have done to my Landy since buying it 4 Months ago. So, had an issue with heat in the cab which is now sorted after plugging various holes and inlets. Brake disks and pads changed, the front discs were 4mm thick!!! Rear ones a little better but not much. Now it stops!!!!
Changed all the tie rod ends and had the steering re-alligned. Got a new drop arm and damper on the way.
Oil service and radiator service after having a rad leak welded, and also changed all four fan belts.
One of the coolant inlets have snapped off from the plenum, so I have a new plenum to fit. I will be taking some pics and uploading them as I go.
New oil pressure switched fised a nasty leak, so now the only puddle I'm leaving is air con water.....woo hoo.
New wind screen washer bottle fitted....old one missing!!!
I have been really lucky as I have just found a local mechanic who is really good with old landys and rangies.
Pics to follow!!!
Old Nov 24, 2011 | 09:40 PM
Good for you!!! Keep us posted.
Old Nov 25, 2011 | 11:42 AM
Danny Lee 97 Disco's Avatar
Great news. What year is it? Put that in your signature please, helps avoid us having to ask. Glad to hear it's working out for you.
Havoc556
Oct 25, 2011 08:32 AM
RegT
May 10, 2010 09:50 PM
