Bumper Mod
Old Jun 18, 2011 | 12:03 AM
  #21
Danny Lee 97 Disco's Avatar
If you go offroad much, the plastic will remove it self somewhat as will the running boards if the mounts rusted like mine did. I completely removed all the plastic even the end pieces, I was thinnking about leaving them on, but they are almost worthless.
I like the Saudi style grilles. I'll eventually get around to something like that even though I prefer the metal bars or tube styles better, but I do have some expanded metal ere, I may try that, also have some light guage stuff similar to Turf's.
What did you use to frame yours Turf?
Old Jun 18, 2011 | 08:05 AM
  #22
turf63's Avatar
There's very little work needed at all when you do that grill. Literally when you cut out the guts in the middle the piece of gutter guard you buy at home depot (5$, then pop the retaining clips off) literally drops right in. Just need to fold up the two bottom corners a tad so it sits flat. Then you epoxy it down with a bunch of weight on it to hold it flat. Voila! Custom grill, 5$ in metal, 5$ in epoxy
Old Jun 19, 2011 | 09:01 PM
  #23
wheelgarage's Avatar
What did you use to cut it, a dremel? I was considering using my air saw....
Old Jun 19, 2011 | 10:12 PM
  #24
honda50r's Avatar
I used a zip saw, then sanded the rough edges. Worked great
Old Jun 19, 2011 | 11:33 PM
  #25
Right on!
onewingman
Sep 30, 2014 09:09 PM
HelenaRover
Aug 13, 2012 10:59 AM
HelenaRover
Jul 30, 2012 09:39 AM
Pwn777
Nov 11, 2009 04:54 AM
mikemeyer0
Apr 15, 2005 05:42 PM
