A/C help
Old Aug 14, 2007 | 12:14 PM
indys2k's Avatar
Default RE: A/C help
already tried to jumper that switch, did not do anything for me. You are right there is only a switch on the H (high) side and not on the L (low side).
Old Jul 1, 2012 | 08:18 PM
waymore's Avatar
Default Great advice
I was having the same issue as the original poster, okdiscoguy had the right answer for my issue. Light was not illuminating on the dash switch. I pressed harder and it came on, kicking in the compressor and ac worked like a charm. Thanks for the advice.
Old Jul 2, 2012 | 03:12 PM
jfall's Avatar
Please don't run the compressor with it jumped to +.
If you are overcharged with Freon, you don't have the high side limit switch to keep you from blowing up your compressor.
I over charged mine once and the compressor started to cycle on and off.
That' what you need to save yourself from an overcharge of Freon.
Speed racer
Oct 11, 2008 10:56 PM
Roca316
Mar 18, 2008 11:33 AM
scottinoz
Jun 30, 2007 09:49 AM
cassie11
Jun 23, 2006 10:26 AM
