a/c question
Old Jun 2, 2013 | 09:16 PM
penlertuning's Avatar
3rd Gear
Default a/c question
Hi guys,
I have a 97 disco with the a/c inop. If I push the button in the light does not illuminate. I checked the fuses and they are fine. I can hear the relay in the passenger kickpanel click when I depress the button. I can hear the fan kick on as well. I do not think the compressor clutch is engaging. Is there another likely relay, pressure switch etc. that I should look into? Would sending 12 volts to the compressor be a good test to see if the clutch pulls in?
Thanks in advance for the help!
Old Jun 2, 2013 | 09:25 PM
There is a pressure switch, if refrigerant low, compressor won't come on. Some parts stores rent/loan gauges.
colemtd
Mar 30, 2019 08:57 PM
