Caliper repair
Old Feb 8, 2018 | 12:15 PM
czkevin's Avatar
Default Caliper repair
I am currently replacing the seals on the front passenger side caliper and replacing the disks and pads. I have to remove the hub from the disk in order to replace the disk. Where can I get the socket or wrench to remove the star bolts to remove the hub from the disk?
Old Feb 8, 2018 | 12:48 PM
OverRover's Avatar
Nothing special just a 12pt. 14MM socket. Here is a good write up > https://landroverforums.com/forum/di...earings-44462/
If you have an air impact wrench than all the better, but it can be done with just a breaker bar.
There is a simple trick in the video (@ 3:40), but just put on 3 lug nut first before you remove the bolts.
Old Feb 8, 2018 | 06:29 PM
czkevin's Avatar
thanks a bunch
SeanPaul
Jan 22, 2016 05:03 PM
TennesseeRover
Mar 19, 2014 08:16 AM
zee
Jun 20, 2012 07:50 PM
