Cam shaft position sensor.
Old Oct 25, 2018 | 04:01 PM
aemnky606's Avatar
Default Cam shaft position sensor.
My cam shaft sensor o-ring failed. Can I just use right stuff on it or do I need to find a o-ring?
Old Oct 25, 2018 | 04:19 PM
OverRover's Avatar
Could you use RTV.....I think the questions is WHY would you?
IMHO, I would not do a HalfA$$ fix with RTV when a proper O ring ( ERR4815 ) is less than $2.00 > https://www.roverparts.com/Parts/ERR4815G
IDK the size, but I'm sure you could match the correct size at NAPA if you don't want to order online.
It's your call. Good Luck!
Old Oct 25, 2018 | 04:48 PM
aemnky606's Avatar
Well further looking into this and after removing the sensor it seems it has both RTV and a o-ring. I have an huge assortment of o rings at work so it will be going back in with just an o-ring.
Old Oct 25, 2018 | 05:12 PM
OverRover's Avatar
So it looks like someone already tried to booger up this simple repair.
O rings AND RTV =
That's a good idea to just use the o ring and fix it right.
And in a Capt Obvious voice.....Just be sure it's rated for motor oil (something like Buna-N).
Old Oct 25, 2018 | 06:52 PM
ihscouts's Avatar
A good hardware store usually has them if you don't find what your looking for.
Old Oct 25, 2018 | 07:26 PM
aemnky606's Avatar
O rings AND RTV =
I'm thinking they used rtv because the o-ring is just crumbling. Kinda like it was not oil rated.
Old Oct 29, 2018 | 12:04 PM
hrhoward's Avatar
And those are few and far between. Luckily, There is one just a couple of miles down the road from me. We have an account there.
couzteau
Aug 2, 2024 08:06 AM
dirklemond
Oct 24, 2012 01:39 PM
oilspotLR
Jul 24, 2012 11:05 PM
pbeats
May 14, 2012 04:15 PM
cgeschwell
Feb 23, 2011 01:01 PM
