Camber/ alignment problem
Old Apr 29, 2011 | 12:21 PM
kenk's Avatar
Originally Posted by Cosmic88
I forgot about the bolt Pattern on the flanges... Been a couple years since ive had my ball off... Married with two kids
Is there any play in the pins or the bearings? Wheel off the ground, rock the wheel with hands at 12 and 6 oclock is the pin check and 3 & 9 is bearing check... you probably already knew and checked that.
Probably worth a check, I did a full rebuild(new pin,bushing,bearing,seals) a little over a year ago, but who knows.
I'm gonna tear it apart, inspect everything, put the stub axle back on the right way this time( flat facing up), and take it to have the alignment checked. If indeed the camber is that far off, I'll just swap the entire housing off my parts car. I was trying to avoid that being how much time and money I had into rebuilding and re-sealing my current one.
Old Apr 29, 2011 | 07:29 PM
Just go find a good 4wheel aligment guy and let him tell you what is wrong.
Drubie22
Jan 26, 2018 03:49 AM
sdrovn
Dec 21, 2007 10:38 AM
Waggy23
May 16, 2007 10:00 PM
Bubba_13
Sep 7, 2006 11:05 AM
jomeheretu11
Oct 31, 2005 06:55 AM
