Positive Wheel Camber
Old Apr 14, 2015 | 10:21 AM
Drubie22's Avatar
Default Positive Wheel Camber
Hey everyone! I picked up my first Disco 2 last year and have slowly been working on it. I replaced the tires and upon inspection of the old tires found that the outside of the treads were worn more than the inside. Curious, I analyzed the wheel camber and it appears as though the truck has a positive camber. Are all Discos this way? If not is this something I should get looked at? The front wheels appear to have the same slight camber as the rear so it seems intentional. Anyway, any information would help.
Old Apr 14, 2015 | 11:16 PM
jafir's Avatar
Your tire wear is almost certainly caused by toe, not camber.
As far as camber is concerned:
⇒ Camber angle - Front, up to VIN 2A 754807 - unladen condition –10' ± 30'
⇒ Camber angle - Front, from VIN 2A 754808 - unladen condition +20' ± 30' "
Old Jan 25, 2018 | 08:09 PM
Extinct's Avatar
Old thread I know, but wondering how camber is even adjusted on these? I saw nothing in RAVE
Old Jan 25, 2018 | 08:11 PM
jafir's Avatar
You don’t “adjust” camber on a solid axle vehicle. You can replace things that are worn or perhaps bent. Otherwise it’s fixed, not adjustable.
Old Jan 26, 2018 | 03:49 AM
OffroadFrance's Avatar
X1 .............. there is no 'normal adjustment' for camber adjustment only castor correction links for 2" -4" lift. It needs putting into a tire bay and the tracking checking.
kenk
Apr 29, 2011 07:29 PM
mherson
Oct 28, 2010 08:15 PM
thomas22
Jul 25, 2009 04:35 PM
jcolumbia23
Oct 3, 2007 12:12 PM
98roverguy
Aug 22, 2007 05:52 PM
