Camel trophy d1 ?
Old Jun 4, 2013 | 07:05 PM
  #41
Roflcopter's Avatar
This one has solid disk, with a 2 piston caliper, with 2 brake lines going to it?
Old Jun 4, 2013 | 07:06 PM
  #42
jafir's Avatar
That sounds kind of like range rover classic.
Old Jun 4, 2013 | 07:30 PM
  #43
Roflcopter's Avatar
Well just so have it, I have a 91 and you are right....the only difference is the disk. But they are the same thickness . Ordering one now.
Old Jun 4, 2013 | 08:09 PM
  #44
Roflcopter's Avatar
Is there a difference between the abs and non abs caliper on the range rovers? They look the same, the one on the disco looks the same but has a Bleed screw on the outside of the caliper that looks broke... :/ Hrmm
Old Jun 5, 2013 | 07:11 AM
  #45
drowssap's Avatar
it does sound like a classic the front caliper were 4 piston w/ two brake lines & the rear were two piston at least on mine.
check advanced auto I bought RRC rebuilt calipers a few months ago and they were like $60.00 -70.00 each and were loaded (pads and hardware)
Old Jun 5, 2013 | 01:06 PM
  #46
Roflcopter's Avatar
My 1991 RRC with abs has 2 piston per front wheel caliper. The rear has a single piston per wheel. I looked at my RRC and it is the same as the one I have removed from the disco. Also, does anyone know what the body number is? Is it on the driver side inside the engine bay? Also, what does the number above the vin mean on the vin plate under the hood. It has 6 characters. Is that a uk regiatration mark? Also, I misread the mileage....it is 17,000 kilometers..... 10600 ish miles..... woah.....
Old Jun 5, 2013 | 11:32 PM
  #47
Roflcopter's Avatar
Caliper and heritage certificate/tech sheet on the way. Also, here. You might want to hear it run
Old Jun 5, 2013 | 11:59 PM
  #48
jafir's Avatar
That's awesome. I wish I had a 200tdi in my 90.
Old Jun 6, 2013 | 08:10 AM
  #49
Sam95disco's Avatar
I would drive it just like that, that sound of the engine did it for me.
Old Jun 8, 2013 | 03:42 PM
  #50
Roflcopter's Avatar
Here is an update with pictures!
Deal of the century for someone in colorado. Camel trophey discovery - Page 4 - Defender Source
Trophyman
Aug 23, 2007 10:04 AM
SpeedAgent
Appearance & Camping Set Ups
Aug 8, 2007 10:19 AM
sébastien
Jun 7, 2007 04:25 PM
mikydrippin
May 31, 2007 04:26 AM
billstown
Nov 29, 2006 07:50 PM
