camel trophy paint
Old Jun 3, 2014 | 12:21 PM
  #61
EricTyrrell's Avatar
For the HVLP guns I've seen, that compressor is more than enough. They typically only take about 4.5cfm at 40psi. That compressor can do 5cfm at 100psi.
Old Jun 3, 2014 | 08:28 PM
  #62
TOM R's Avatar
My gun is not hvlp, just gravity feed real cheapo, it is supposed to run 40 psi but I lent it out once and guy screwed with all the setting and I never got it right again so just run higher psi , think that tank will do it, better if you can borrow another to hook together for more capacity, done this before it works
There is not a lot to paint, just a ton to mask can easily take 1-2 hours to mask well, that's for primary color not including masking other stuff for second color
If you use the same paint, I broke down the ratio to pints
1 pint paint + 2 oz reducer + 1 oz hardner iirc, the setup is to mix entire gallon but shelf life is 8 hours so ...
Old Feb 9, 2016 | 03:58 PM
  #63
afonseca's Avatar
4th Gear
Hi Tom,
Can you please be so kind to tell what's the lift and tire size of the first picture?
Thanks in advance for any help you may provide!
Regards, AF
Old Feb 10, 2016 | 09:49 AM
  #64
TOM R's Avatar
2" OME HD , 245/75/16 all terrains e rated
Old Feb 18, 2016 | 06:09 PM
  #65
afonseca's Avatar
4th Gear
Hi Tom,
Thanks for your kind answer but I believe there was a misunderstanding!
I was referring to the attached picture. Can you tell what's the lift and tire size of this vehicle?
Regards, AF
impretzle
Mar 12, 2013 11:39 AM
SpeedAgent
Appearance & Camping Set Ups
Aug 8, 2007 10:19 AM
sébastien
Jun 7, 2007 04:25 PM
mikydrippin
May 31, 2007 04:26 AM
billstown
Nov 29, 2006 07:50 PM
