camel trophy paint
My gun is not hvlp, just gravity feed real cheapo, it is supposed to run 40 psi but I lent it out once and guy screwed with all the setting and I never got it right again so just run higher psi , think that tank will do it, better if you can borrow another to hook together for more capacity, done this before it works
There is not a lot to paint, just a ton to mask can easily take 1-2 hours to mask well, that's for primary color not including masking other stuff for second color
If you use the same paint, I broke down the ratio to pints
1 pint paint + 2 oz reducer + 1 oz hardner iirc, the setup is to mix entire gallon but shelf life is 8 hours so ...
impretzle
Mar 12, 2013 11:39 AM
mikydrippin
May 31, 2007 04:26 AM
billstown
Nov 29, 2006 07:50 PM
