Can new Coolant silence warm running tick ?
Old Yesterday | 09:13 AM
disco96sd's Avatar
Default Can new Coolant silence warm running tick ?
So I developed a warm running tick - it was coming from the front of the engine - not lifter or rocker arm area (put new lifters in when did heads 15k miles ago - changed the oil with new filter but that didn't do anything - so upon checking some more I noticed my coolant overflow bottle was low so I added some water - checked again several days later and while the level was good could tell there was some particals in the coolant - so decided to drain and flush with hose - added new coolant and tick went away - first time I have heard of a coolant related tick
Old Yesterday | 02:44 PM
WaltNYC's Avatar
It doesn't seem likely. Though I have no possible explanation for why the tick went away.
A 'tick' at the front of the engine may indicate a water pump going bad. A worn bearing can make a similar (not the same) sound.
Old Yesterday | 07:49 PM
disco96sd's Avatar
the water pump was replaced with the head job along with a new oil pump timing chain and gears - it appears there is some lubricant properties in antifreeze - perhaps something to do with it ?
KingKoopa
Jun 17, 2017 07:32 PM
zski128
Jan 10, 2014 11:26 AM
Dflood
Sep 22, 2012 06:59 PM
Disco Fuego
Apr 21, 2012 11:17 AM
97XD
Feb 2, 2007 07:46 PM
